Ana içeriğe geç
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
What should I do?
I have an iMac 27 2017, the HDD broke, which is better: 1- replace the HDD with a sata SSD. 2- replace the HDD with a SATA SSD and replace the 128GB M2 with a 2Tb M2. 3- remove the sata HDD and replace the 128GB M2 with a 2Tb M2, leaving only this M2?
Gabriel
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hello Gabriel! Let's explore your options for upgrading your iMac 27" 2017 after the HDD failure. Each choice has its own advantages, so let's break them down:
1. **Replace HDD with a SATA SSD**:
- This is a straightforward option. You'll remove the broken HDD and replace it with a SATA SSD. It's a cost-effective solution that will significantly improve overall performance compared to the original HDD.
- You won't need to touch the M.2 slot or the existing 128GB M.2 drive.
- **Estimated cost**: Depends on the SSD capacity you choose.
2. **Replace HDD with a SATA SSD and Upgrade the M.2 Drive**:
- In addition to replacing the HDD with an SSD, you can also upgrade the M.2 drive from the existing 128GB to a spacious 2TB.
- This option provides both faster storage for your system (SSD) and ample storage capacity (2TB M.2).
- **Estimated cost**: Higher than option 1 due to the additional M.2 drive cost.
3. **Remove SATA HDD and Replace 128GB M.2 with a 2TB M.2**:
- This option removes the SATA HDD entirely, leaving only the M.2 drive for storage.
- You'll have a single 2TB M.2 drive, which is fast and spacious.
- **Estimated cost**: Similar to option 2, as you're still upgrading the M.2 drive.
**Considerations**:
- If you need more storage space, go for options 2 or 3.
- If budget is a concern, option 1 is the most economical.
- Remember to back up your data before any upgrades.
- If you're comfortable with the process, you can perform the upgrade yourself using guides like the ones provided by iFixit.
Ultimately, the choice depends on your storage needs, budget, and technical comfort level. Happy upgrading!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Gabriel Bacchi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 109
