Ana içeriğe geç
Repair guides and disassembly information for the new base-model 14-inch MacBook Pro, released November 2023, refreshed with the Apple-designed M3 SoC. Successor to the 13-inch Touch Bar MacBook Pro with M2.
MacBook water in vents.
So maybe a week ago, I was keeping my macbook on the table closed. And then i spilled some water on the table, and some of the water, went into the bottom vents. So i layed it upside down. And then I shook the water out. So now I'm very worried. I spent 1500 on this machine. If anyone can give me a detailed explanation on how i can check if any water damage has been done. And I've been using the macbook for about a week. And working great! I did run self service diagnostics from apple, including the mac resource inspector(mri) and i ran the normal diagnostics multiple times. And no issue. And also i did benchmarks and compared them. And they were the same.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
5 Yorum:
Anyone that can help me out will be greatly apreciated!
tarafından
@altname - Is this a duplicate of your question? tiny bit of water in bottom vents(I forgot what side) its so odd to have two people with the exact same system with the same issue!
tarafından
well fine yes. I wanted 2 opinions. so
tarafından
@danj it is duplicate. can you still answer?
tarafından
@vjnfd3gkfrelm9b - Let’s not over do it. One posting will suffice!
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
start by letting it air dry for 24 hours if it wasnt a large amount & it was only water. assuming you probably already did that, and there is no issues with performance, id assume water damage was minimal, and you might want to just do a thorough check and clean your Mac's internals. but if you do want to take a look, id recommend looking at this MacBook water damage - The definitive guide - iFixit
Bu yanıt yardımcı oldu mu?
Puan 0
10 Yorum:
@timtomissus
All right. But is there a way that if i open it up, can you tell me what to look for, to find any sort of damage whatsoever?
tarafından
@altname usually corrosion is a white or orange usually powdery or waterspot like. ill attach images if it helps ^^
tarafından
@timtomissus all right. So are there any signs? or is that it?
tarafından
@timtomissuss once i open it up, i'll post a few pictures on here. Can you help me from there?
tarafından
@timtomissus Also i have a question, how do I put the bottom plate back on? i only saw videos on how to open it. And i tried to understand the ifixit guide on how to put it back. But i couldn't really understand. Also, wdym by waterspot like? Do you mean like a water drop?
tarafından
5 tane daha yorum göster
Yorum Ekle
You’ll need to clean the area with 90% IPA as the water stain is the Minerals which is in the Water and corrosion it caused.
Did you review the Apple service manual which Apple now offers for your system? Here’s a link to it MacBook Pro (13-inch, M1, 2020) Repair Manual jump down to the procedures section the last section is the uppercase. See if that helps you.
Puan 0
1 Yorum:
i'll open it up.
tarafından
Yorum Ekle
Yanıtını ekle
Alt name sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 44
Her zaman: 423
