I'm getting double images on my TV
I'm getting a sort of shadowing on my TV with a pink line around the shadows. I've changed antenna cable and that didn't work.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Well I will suggest you to check out the following: https://www.sony.com/electronics/support...
Bu yanıt yardımcı oldu mu?
@rhiannonfayblay this is commonly a T-con board error (Gamma Chip). Since your TV is a bit off-brand we would need to see what it displays. Post some pictures of what this all looks like. After that, unplug it and remove the back cover. Then take a look at the boards. Check for loose cables as well as corrosion on the cable connectors. Look for obviously damaged components. Post some pictures of all of your boards etc. with your Question. That way we can see what you see.
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 12
