Ana içeriğe geç
Model A1347. 21 Temmuz 2011'de piyasaya sürüldü. Core i5 veya Core i7 işlemci. Thunderbolt. Bu birim aynı zamanda Mac mini Server yapılandırmasını çalıştırmak için de kullanılır.
Stuck in loop boot and will only safe boot
First I tried to restore using mac OS recovery which did not complete the install. Due to posable expired certificate issue.
So I download High Sierra and made a bootable installer. Formatted the SSD and ran the installation, this did not complete the installation process. But then enters a boot loop, boot runs then restarts to about 3/4 off the grey install screen, then reboots again.
Then on the start of a reboot pressed the shift and managed to complete the installation process in safe mode.
Now it is continuously still stuck in loop boot. It starts to 3/4 grey startup screen and restart again.
But you can force it into safe mode. Also now the start chime now has stoped working.
I have tried many times now and have lost my way forward.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
To get around the expired Cert you'll need to use a second Mac system to download the OS installer file and then setup a USB thumb drive as a bootable OS installer (don't forget to first format the USB drive to GUID-Journaled) Goto this cute to get the OS file How to download and install macOS then follow this guide Create a bootable installer for macOS.
See if that gets you going, good luck! You may need a new drive.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
john sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 266
