Ana içeriğe geç
How do I fix my 360 it says unrecognized disc
everytime i put in a game it says open tray or unrecognized discive cleaned it very well cleaned the lense jus wont work sounds like it wants to but wont
Bu iyi bir soru mu?
Puan 13
1 Yorum
ive dione that with a brand new ganme an it keeps spinning
will not read it
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
unfortunately there is no simple solution :(
1. Open your Xbox and CD drive. Clean all optical elements on it.
2. If it did not help find 2 small potentiometers and try to increase voltage on the laser.
3. Replace your cd drive - but you need to reflash a new one with the old cd key.
If you don't understand how it works it will be much better to go to any repair shop - I don't know how much it costs in the US but in London its about 20 quid (just the labour)
Peter
Bu yanıt yardımcı oldu mu?
Puan 8
4 Yorum:
+1 Piotr, good answer. kanoa, start off with the easy and inexpensive stuff, clean your laser. You can use a cleaning DVD for that, they are available at most department stores.
tarafından
ccccccyuigfddfghjkl;lkjh
tarafından
I did this like 2 months ago and my Xbox 360 works like brand new
tarafından
But it is not working again now, why?
tarafından
Yorum Ekle
there IS a simple solution. You'll have to open the DVD drive, and replace the laser with an identical one. you can replace the entire "sled" assembly. but the DVD logic board MUST stay with the xbox's motherboard. (unless you have away to flash the board)
Puan 1
Yorum Ekle
We can clean the disc when its recognized disc. All we do is toothpaste and will leave in five mins.Then wash it to see it works.
Puan -1
4 Yorum:
After u put the toothpaste in the game how do u grt it off. Wipe it run water over it or what.
tarafından
I think that toothpaste can destroy the disk
tarafından
yes it can do not try that
tarafından
Hand sanitizer I use then runic under water and wipe with toilet roll as its softer than kitchen roll
tarafından
Yorum Ekle
Yanıtını ekle
kanoa sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 36
Her zaman: 47,943
