Ana içeriğe geç
23 Haziran 1996'da piyasaya sürülen ve NUS-001 model numarasına sahip olan N64, Nintendo'nun ilk 64-bit oyun konsoludur ve Switch'in piyasaya sürülmesine kadar tek 64-bit konsolu olmuştur (GameCube, Wii ve Wii U, 64-bit kayan noktalı işlemler gerçekleştirebiliyordu ancak bu, gerçek 64-bit mimarisi değildir).
Incredibly dark image - help!
Hi,
Found my old N64 tucked away and trying to get it to work.
It’s on a SCART cable, and I get audio just fine, but the image in the screen is INCREDIBLY dark. Like not there at all. With brightness/contrast settings cranked on the TV you can just about make out the image.
I’ve re-seated and cleaned all cables and the expansion pack, and tried multiple games
Any ideas?
Thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
5 Yorum
Hey there, are you trying to play your N64 on an HD TV or using a CRT TV?
tarafından
HDTV.
Thanks
tarafından
Have you tried using different games, and tried cleaning the N64 cartridge’s pins?
tarafından
@spawn2048 how do you connect your N64 to your HDTV? Have you tried an older TV? what make and model is your TV?
tarafından
@jmehnert yes, as stated in the original question…
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi!
I advise to clean the AV port first. If that didn’t worked, then replace the AV cable for a new one. If that didn’t worked, then try the console on a different TV to determine if there is something wrong with the console. If the image is like still super dark, then open up the console and clean it all (also the cartridge pins on the motherboard) and try again.
Could you also share some pictures regarding how the console is connected to your TV?
Please let us know how it goes!
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Bit the bullet and bought a new cable. Now on AV rather than SCART and working fine. So either broken cable, or broken SCART port on TV
tarafından
Hi!
Alright. Probably the cable (in most cases). You could try the SCART port with the new cable. Could be the SCART adapter as well. Good to hear that all is ok now :)!
tarafından
Yorum Ekle
Yanıtını ekle
spawn2048 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 31
Her zaman: 1,036
