Ana içeriğe geç
Logitech MX Anywhere 3 taşınabilir kablosuz fare için onarım ve sökme bilgileri. 2020'de piyasaya sürülmüştür ve 910-005986, 910-005833, 910-005987 veya 910-005985 model numaralarıyla tanımlanır.
Click is not working
Hello everyone!
Well, I have MX Anywhere 3 and I have now this issue: left side is not clicking. You need a stronger click/click in a precise spot of this side of the mouse to make the click work. I have this product for more than 5 years now. I saw there are some videos about how to fix it at home... and I am a bit afraid buying the tools/paying someone to fix it and then having the issue again...
Do you guys have any tips or instructions that I could follow to solve this problem? Have you faced this problem as well? Is really worth fixing it?
Thank you very much.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@amandazorzhan "bit afraid buying the tools/paying someone to fix it" first off you are not going to pay anyone. This is ifixit where YOU are empowered to fix it yourself. You can absolutely do it. You know to use this excellent guide Logitech MX Anywhere 3 Nasıl Açılır and not some shaky youtube video ;-)
Now this "need a stronger click/click in a precise spot" sounds like an issue with the micro switch. It could just be that the plastic is starting to wear a bit. 5 Years is actually a really good life expectancy. Now, once your mouse is apart, take a look at those pieces.
Resim
If you find that they have worn. Get some nice adhesive and just add some "mass" to it. I commonly use little felt pads from the larger department stores and cut a small piece and glue it on top. Less rigid gives a better mileage :-)
There is a whole community of fixers here that is willing to help you, if needed. No worries, You got this!
Repair is War on Entropy!
Bu yanıt yardımcı oldu mu?
Puan 3
3 Yorum:
After I reassembled my MX Anywhere 3 mouse, when I turn on the switch, the LED at the back of the mouse wheel only blinks red. I have already tried charging it, but the red LED keeps blinking whether it is charging (with the power switch turned on or off) or not charging (with the power switch turned on). Additionally, the LED on the Bluetooth switch, which has 3 options to connect up to 3 devices, no longer turns on. Does anyone can help me?
tarafından Paylaş
I added two layers of regular adhesive tape and it did the trick. Thanks!
tarafından Paylaş
I added four layers of Scotch tape, and it seems to be working well. that does wear out because it does compress over time so you might need to do it again
tarafından Paylaş
Yorum Ekle
Hi Amanda, I believe the only way is to open it up and clean the button with rubbing/ isopropyl alcohol. One think you could try is using compressed air to clean under the area.
Puan 0
1 Yorum:
tarafından Paylaş
Yorum Ekle
I've tried both usual methods, using lubricant on the micro buttons inside the mouse and blowing air inside, but neither worked.⏎
I also noticed that if I use the mouse without the cover, the left click and double-click work fine, so the problem isn't with the buttons inside but with the buttons on the cover.
Puan 0
1 Yorum:
There are 3 screws on top cover, if you take those out you can actually see interior of the buttons and use a thin brush to clean up all the dust i did this and my mouse was fixed
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Amanda Zorzhan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 17
Son 7 gün: 93
Son 30 gün: 499
Her zaman: 14,934
