Ana içeriğe geç
Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
Why does it only work on a charger?
my psp go is not turning on and the charging light wont come on either....only when i plug the charger into it and play it will turn on ........if i remove the charger it turns back off.....help pplzzz
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
jahtav, sure sounds like a bad battery. It appears like it does not hold a charge. Of course, make sure that the contacts are clean etc. Follow this guide to change your battery. You can get a new battery from here Sony PSP Go Battery as well as many other places. Once you replace the battery, and it still does not charge, you can check the fuses on your logic board. Check those for continuity with a multimeter. Hope this helps, good luck.
Replace a model LIP1412 battery compatible with the Sony PSP Go game console. Görseli
Ürün
Sony PSP Go Battery
$19.99
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Use the spare chager
Puan 0
Yorum Ekle
Yanıtını ekle
jahtav sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 6,767
