Ana içeriğe geç
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache and an optional AMD Radeon R9 M370X dGPU.
Dead power button fix
My 2015 MBP has a dead power button. I have determined that it is completely dead at the contact pad as if I touch it with something metal, it doesn't work. Every other key works. Is there something I can do, or does the whole keyboard need replacing?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
To be clear, you are able to power on the system by shorting out the Power Pads, so it’s clearly the button that’s failed.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
I haven't tried that. I may have to replace the entire top case.
tarafından
@sickminecraft45 - I would start off checking if you can bypass the keyboard first.
tarafından
Yorum Ekle
Yanıtını ekle
Sickminecraft45 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 75
