My battery is so weak
How to make my battery so strong
Make a strong battery
Bu iyi bir soru mu?
Bu iyi bir soru mu?
1. Turn on the Power saving mode
You can turn on the Power saving mode, and go to Settings > Battery > Power saving mode. When it is turned on, it will automatically optimize the performance of the phone, stop the background synchronization function and prolong the battery life. You can also adjust the items to be optimized by yourself, go to Settings > Battery > turn on Power saving mode > Default optimization and add or remove some functions.
2. Turn off applications with high power consumption
You can check which app consumes more power by Settings, go to Settings > Battery > Battery Usage, click the specific app and choose to close the apps you don't need to use temporarily.
3. Turn on the Auto select screen refresh rate (If the phone is only suitable for 60Hz, this function is not supported )
Go to Settings > search for Screen refresh rate > Auto select. The phone will switch the screen refresh rate according to the application to avoid consuming more power due to using a high refresh rate all the time.
Bu yanıt yardımcı oldu mu?
@vishalshar99819 you can't make a battery "strong". If it does no longer hold a proper charge, you need to replace the battery. After that you can set your battery savings settings etc. but it does not make your battery "stronger". It just makes it last longer. Since iFixit does not yet have a specific guide for that, use something like thisvideo for the battery replacement.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Son 24 Saat: 7
Son 7 gün: 12
Son 30 gün: 30
Her zaman: 1,391
9 Yorum
My battery is run fast how to repair the battery??
Arber Tiktok tarafından
NiTiN Thakor tarafından
Pengisian kebaterai terlalu lamban/ lama penuhnya...
Mulyadi tarafından
My phone battery so weak
Rai Alone tarafından
Bettry not working
Rathod shilaben Ashok Bhai tarafından
4 tane daha yorum göster
