Ana içeriğe geç
Mayıs 2020'de piyasaya sürülen 13 inç MacBook Pro; dört çekirdekli 10. nesil Intel Core i5 ve i7 işlemciler ile entegre Intel Iris Plus grafik birimine sahiptir. (Dört Thunderbolt 3 portuna sahip A2251/EMC3348 modeli)
Max Screen Brightness Diminished After Screen Replacement
Hey, all,
Need some advice. I replaced the display on a 2020 Intel 13" Macbook Pro and it worked fine at first. Then it went dim. Not like the brightness just went down and locked itself, but like the max brightness is now 50% lower than it was before. I can still adjust the brightness, but max brightness is super dim now. It temporarily resolved itself after a NVRAM reset but continued after logging into the machine. SMC reset didn't help at all. I went in and checked my connections and everything looked fine. I also checked the sticker on the display and it had the correct A2251 number on it.
I'm not too sure where to look from here. It almost seems like, when it has yet to do a checksum on boot/login (booting after NVRAM reset), it just lets the backlight chill, no issues. But when doing its checks during initial login, it sees something it doesn't like and rejects it, which will stay consistent until another NVRAM reset.
Any advice is appreciated, just wanted to cover all my bases before claiming a faulty part. Thank you!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Where did you get the display? Is it new or used.
See if TrueTone services are working going into the display settings.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Got it from MobileSentrix, it's one of their genuine pulls. It has TrueTone marked as available
tarafından
@cynical32713 - Sorry this display has issues. Can you get a replacement user warranty?
tarafından
Yorum Ekle
Hi Cleb,
In case you haven't already, I would advise you to calibrate your screen properly before you consider a replacement/any other measures.
For more info, see here:https://support.apple.com/en-ca/guide/ma...
Puan 0
Yorum Ekle
Yanıtını ekle
cleb sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 18
Her zaman: 699
