My tablet wont accept power or charge
my tablet wont charge when i plug it in and the power supplt turns off whith a small click sound and i cant find the board the charge port is attached to
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@timyyyy it does not have a "charging board" the DC in connector is soldered to the main. The most common issues are bad DC plug, a bad DC in Jack or an issues with the charging circuit on the mainboard. Make sure that your charger is actually working. You also want to consider replacing the battery. Your tablet does not work without a battery. Your battery may have failed and may not even be seen by your tablet. If your tablet does not "know" there is no battery, it will not turn on.
A new battery will also provide you with known-well starting point for any further troubleshooting. Use these guides Dell XPS 18 to work on it
Bu yanıt yardımcı oldu mu?
it is seperate from the main board i am not blind
i tested diffrent chargers
i dosent hold charge i will look for replacements
ive also drop the battery by error
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 29
Her zaman: 29
