My left click becomes double-clicking
Every time that I click, it becomes double click
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Just pressing the button once producing a second click is what I am assuming you have entered. I have had that happen on my own logitech mice after a while, and it was the mechanical button inside the mouse wearing out (there is a tiny spring which weakened, and allowed the inner switch part to bounce during the movement.
Assuming it is on a PC, check the mouse isn't programmed to doubleclick (it might be a setting). You could also try adjusting the double click rate which might help not have it detect it.
If it is the button, opening it up and replacing it (which would need soldering skills) would work. The button likely has a part number on it, and likely could find it at a place like Digikey.
Bu yanıt yardımcı oldu mu?
Hey Mate, if you left click on your computer does it have the same problem?
If if is a pc, try hooking up a different mouse. This will isolate the keyboard and the mouse. If the control key gets busted and tells the computer that control is being held down, the clicking can go haywire.
So let us know the result of trying on the trackpad/different mouse.
Cheers
Falcon16
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 35
Her zaman: 440
1 Yorum
Dose this happen when you click your left click more then once?
Braiden Hill tarafından
