Ana içeriğe geç
Model A2159, EMC 3301. Giriş seviyesi 13 inç MacBook Pro'nun yenilenmiş bir sürümüdür. Gümüş ve Uzay Grisi renk seçenekleriyle sunulur. Temmuz 2019'da piyasaya sürülmüştür.
Original Battery not recognized
Hi,
I was assembling my macbook pro 13" 2019 and I have this problem: my macbook not recognized the original battery.
Have I damage the battery flex data cable? because, I pulled of this flex cable and I did not open the connector flex of the mainboard.
Photos:
Resim
Resim
Resim
Thank you,
Update (05/03/24)
Continue:
The only way to turn on my macbook pro is: connecting it to the electical network with my power adapter.
Thank you
Update (05/03/24)
Hi Dan,
Photos:
Resim
Resim
Resim
Resim
Update (05/06/24)
Hi
I have already had a new flex cable !!! and I have just fixed my macbook pro !!!
Thank you for all answers !!
Bu iyi bir soru mu?
Puan 2
3 Yorum
So the only way to use it is to plug it into the wall?
tarafından
Exactly! That is the only way to use my macbook...
If I install Cocunut Battery... It will show "nan"
tarafından
Both connectors seem to be fine and their tabs too, so is it possible that I have damaged the flex cable or the connectors of the mainboard?
I hope I have damaged only that cable...
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Can you post images of both connectors so we can see if they are damaged. If it’s just the cable that’s replaceable MacBook Pro 13" Retina (A1708, A2159, A2338) Battery Daughter Board Cable
Replace the small flex cable that connects the battery daughter board to the logic board. Görseli
Ürün
$16.99
Bu yanıt yardımcı oldu mu?
Puan 1
4 Yorum:
Hi @danj,
Very close to being a short circuit between connector pins 9 and 10 (from the left) in the 2nd image posted above.
What do you think?
tarafından
@jayeff - I would replace the cable for sure, but the real issue is what happed within the connectors.
tarafından
@consu - Looking at the connectors they look OK, so maybe all you’ll need is a new cable! I wish you luck!
tarafından
Thank you so much for your point of view!!
I will write here when I have the new Flex Cable.
tarafından
Yorum Ekle
Yanıtını ekle
Consu sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 25
Her zaman: 500
