ONN tablet shuts OFF randomly
The device shuts down while in use, powering off each time. When it works doesn't seem to have any glitches or operating system issues??
Bu iyi bir soru mu?
Bu iyi bir soru mu?
You can try to wipe the cache partition if it runs Android. You'll have to look up how to do it for your device, this article might help. You follow the same steps as during a factory reset by booting up recovery mode, but select wipe cache partition if that's an option. It won't harm your data, but if you're still concerned you can back it up just in case
This helped my Samsung Galaxy Tab s7 get out of a boot loop once. Still, no idea why it happened but it fixed it
This works because it deletes possibly corrupt system files off of your device
Onn tablets are usually budget, so it could be resetting itself due to it being overloaded with processes (you can check how much storage and RAM you have, if it looks normal then this might not be the issue), it might help to restart your tablet more often and close apps more often. This can also happen when it gets too hot, but it's rare
If the tablet being overloaded is the issue, you can go into developer options and set the background process limit lower and(or) turn ''don't keep activities" on, but I don't suggest this unless nothing works or since it will negatively impact how your apps run and may hurt battery life
If that doesn't work you can try factory resetting it as a last resort, but if that doesn't work either it's probably a hardware issue or a combination of both hardware and software
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 20
