Ana içeriğe geç
A workstation released by Dell in 2012.
Why is it not accepting any form of windows installer?
What I've tried:
1. Tried replacing the dead CMOS battery.
2. Checked/tweaked bios settings (Boot sequence, security settings, etc)
This computer was from a school, But everything was wiped before I got it (including bios settings).
I can't figure it out.
ALTHOUGH, I was able to get ubuntu 19.4 installed and working perfectly well
(For reference: I was using terminal to make the installers. )
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum
Hi @beanman56,
Did you check that you have BIOS → Boot List Option → Legacy setting, enabled?
Did you try updating the BIOS firmware?
tarafından
@jayeff - Legacy is on, I will try seeing if ubuntu would let me open the exe containing the bios update.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If you're using ubuntu terminal to image your bootable media I would try suggesting using RUFUS instead, unfortunately it is a windows only tool (you might be able to get it up and running using something like Wine on linux), but it is the only tool with which I've had success creating bootable media for windows. Check it out here
Make sure you use MBR as the partition scheme and BIOS or UEFI as the target system.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Ben Capehart sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 5
Her zaman: 83
