Ana içeriğe geç
The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
Disc drive is not reading discs.
This Xbox 360 slim was reading discs at one point but I had taken out the laser and put it in another model that needed it. Now I’ve ordered a new disc drive and put the laser in this model and it won’t read discs. When I put a disc in and close tray it says reading and then stops after literally 3 seconds ( I timed it ). I bought this disc drive with the new laser in it from a seller on eBay who didn’t say whether or not it’s working but they did say their Xbox had a RROD after I had messaged them.
Looking for help on what I can do.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi!
Okay, so you changed the disk drive with another drive? You also changed the PCB, I assume? Because this is needed to run games. I think the laser is OK, is everything connected as it should?
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Everything was ok, I only swapped the laser and that’s it. I had forgotten to attach a ribbon cable properly. It was hanging half out :(
I was sure I put it in properly. Then I was going to swap them back and noticed, tested again and it works. Silly silly
tarafından
Hey! Glad that all is okay and that you were able to fix it :)!! It happens sometimes! Have a good one!
tarafından
Yorum Ekle
Yanıtını ekle
Fire Aussie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 215
