Ana içeriğe geç
Repair information and troubleshooting help for the Acer Aspire ES1-111 laptop.
Water went inside my laptop and display is not working
Water went inside my laptop nd display is not working
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The first step in any water damage is to open the device and disconnect any power, including the battery, this will prevent corrosion and further damage,
Here Is a YouTube video demonstrating this process: https://www.youtube.com/watch?v=AOdhsWA-...
But typically, you will want to follow these steps:
  1. ensure the device is powered off
  2. remove all screws on the bottom of the device
  3. try to gently pry the bottom cover off the device
  4. look for the battery (large black rectangle)
    1. disconnect any cables or connectors, leading to the battery.
    2. remove screws holding the battery in place
  5. then fully remove the battery
once you have removed the battery, you can then inspect parts of the laptop for any water damage.
After that it is dependent on what has been damaged, but these steps will ensure that the damage from water is minimized
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Saakshi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 8
Her zaman: 93
