Ana içeriğe geç
Milenyum model deniyor. 2001 yılında çıktı
Hyundai Accent el freni sorunu
Update (05/11/24)
English translation from Turkish original:
Hello, I have a 2000 model Hyundai Accent 1.5 GLS millennium chassis vehicle. My vehicle sticks as soon as I pull the handbrake, regardless of summer or winter months. Then, at the point of moving, the wheels do not turn. I took it to the handle a few times, it said the handbrake rope was worn, changed it, removed the rear wheels and did the internal maintenance and cleaning. After that, when I pulled the handbrake again, there was no change. The adhesion continued. He said that the brake pads were also good. As a result of various tests, we know that they stick due to cold in the winter months. The adhesion continues in the spring and summer months when there is wetness. I would be glad if you could help me to find out what is the reason for this, thank you.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
@mehmetsipahi does your Accent have drum or disk brakes? Which cable did you check/replace (adjuster cable or parking brake cable)? Have you checked the Equalizer assembly? IF both wheels stick it is most likely related to the parking brake cable or the equalizer.
Translate
mehmetsipahi Accent'inizde kampana mı yoksa disk fren mi var? Hangi kabloyu kontrol ettiniz/değiştirdiniz (ayar kablosu veya park freni kablosu)? Ekolayzer grubunu kontrol ettiniz mi? Her iki tekerlek de yapışıyorsa, büyük olasılıkla el freni kablosu veya ekolayzer ile ilgilidir.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
@mehmetsipahi take a look at the Brake part from the workshop manual. Page 35 deals with the parking brake. The issue here maybe bad cables, bad hookup or even bad brake shoes. Since we do not see what yours look like, we can only refer you to a manual. It is in English but hopefully it'll help you anyway.
Now, I did make an attempt to translate the manual. See if this makes sense to you.
Translation
mehmetsipahi atölye kılavuzundan Fren kısmına bir göz atın. Sayfa 35 park freni ile ilgilidir. Buradaki sorun kötü kablolar veya kötü bağlantı veya hatta kötü fren pabuçları olabilir. Sizinkilerin neye benzediğini görmediğimiz için sizi sadece bir kılavuza yönlendirebiliriz. 2001 Hyundai Accent Brakes İngilizce ama umarım yine de size yardımcı olur.
Şimdi, kılavuzu tercüme etmeye çalıştım. Bakalım size mantıklı gelecek mi?2001 Hyundai Accent Brakes.en.tr
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Mehmet Sipahi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 67
Her zaman: 486
