Ana içeriğe geç
Repair and service information for the Ryobi 3300PSI 2.3 GPM Cold Water Gas Pressure Washer with Honda GCV190 Idle Down. Model Number: PSI RY8094
Where can I buy the uploader valve
where can i buy the uploader valve
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@wilmeister37410 if you are referring to the unloader valve by the pump, that is part number 310924003
It is widely available since it has been used in many different pressure washers. Available from Amazon to Walmart.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
this is what the cs told me after 5 hours on hold talking to 4 people. he 1st tried to say that i had to buy the whole pump. but ended up verifying the number
tarafından
the whole problem is they do not have the uploader valve on the parts diagram therefore there is no part number to verify t
he correct fitting of the unloader valves i found
tarafından
Yorum Ekle
Yanıtını ekle
WiLmeister sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 7
Her zaman: 59
