Ana içeriğe geç
Black+Decker CM2040; 40V Lityum batarya sistemine sahip, 20 inç kesme genişliği, 6 kademeli yükseklik ayarı ve hassas kenar kesimi için EDGEMAX gövde tasarımı sunan 3'ü 1 arada bir kablosuz çim biçme makinesidir. İki adet 2.5Ah 40V MAX Lityum batarya ve 15 galonluk çim toplama torbası ile gelir; malçlama, torbalama ve yandan boşaltma biçme modları sunar.
Can I replace the broken battery terminal?
The plastic piece the battery slides into broke off. How difficult is it to replace the broken part? Thanks.
Edited to add - the black piece shown broke off the top of where the battery slides in I’ll include a photo where my husband tried to superglue it It’s not stable though.
If it’s a DIY fix, can anyone please help us find the correct part number?
Thanks!
Resim
Resim
Bu iyi bir soru mu?
Puan 1
2 Yorum
@lorid46982 let's see what it looks like. Post some pictures of the situation with your question :-)
Mevcut bir soruya görsel ekleme
tarafından Paylaş
I tried adding two photos. Can you view them?
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@lorid46982 this does luckily not look like a major structural component. I would suggest a good two part epoxy. Something like J-B Weld Epoxy Putty or Loctite's Plastic bonder. The paste is usually better for this, since you can apply it within the fracture of the plastic pieces and a couple of layer across the top. To add some structural strength get a strip of the fiberglass mesh repair patches and embed that where you place the putty. Something like a layer of putty followed with a strip or two of the mesh, followed by another layer of putty.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
@oldturkey03, thanks for the recommendation. I’ll give it a try.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Lori D sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 471
