Ana içeriğe geç
A1418 / EMC 2833 / Late 2015 / 3.1 GHz Core i5 or 3.3GHz Core i7 Processor. Released October 13, 2015.
Bluetooth devices are disconnecting
I have a 21.5in iMac (2015) running Monterey 12.7.2. It randomly disconnects from all bluetooth devices. I have attempted to reset the bluetooth by deleting the plist data and reseting the bluetooth module. I have checked to see if the bluetooth devices that disconnect work on my MBP and they do without issue. Is there any solution to fixing my iMac?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Do you share BT devices between your systems? I found some devices tend to gravitate to a given system even when you don't want them to. Make sure to keep the BT devices you don't want connected as well as other systems as far as you can. See if that makes a difference.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Would having AirPods that connect and disconnect frequently have anything to do with what you're referring to?
tarafından
@brandonstewart - If they are used between the two systems.
tarafından
Yorum Ekle
Yanıtını ekle
Brandon sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 88
