Ana içeriğe geç
Model A1059 veya A1099 / 20, 40 veya 60 GB sabit disk / dokunmaya duyarlı tıklama tekerleği
iPod only shows power adapter being plugged in to wall outlet?
My iPod will not do any thing, when charge/sync cord is hooked up it will only show a power adapter being plugged into a wall outlet. I cannot get the click wheel to do anything, and when plugged into my PC it does not recognize that I have it hooked up. I have tried changing cords but still no luck. any sugesstions
Update
I have done all of the suggestions and still my 20GB Classic will not go and I have the "power adapter plugging into the wall" sign showing..help this iPod was for grand daughter for xmas..her first.
Bu iyi bir soru mu?
Puan 4
4 Yorum
Just in case :) sometimes after an iPOd gets updated by using an USB cable, and after the iPod reboots, it gets stuck on the "plug in to wall" icon and won't go any further. I would try try a FireWire cable rather than a USB one. Plug the FireWire cable into the wall charger the first time and the update will usually complete successfully.
It would seem that the crucial thing here is to either:
1. Use a wall charger with either a FireWire or USB cable.
OR
2. Use a FireWire cable to connect your iPod to your computer if you have a FireWire connector. Again, I think we need more info to help you out.
tarafından
This should verify it. The iPod wants to be plugged into a power outlet and won't proceed until you do so. You see this icon after you've restored your iPod and the iPod needs to update its firmware. This occurs only when you've plugged your iPod into a USB port or un-powered FireWire port (the 4-pin variety of FireWire ports found on some PCs).
tarafından
Gloria, use a wall charger not your PC
tarafından
I can't seem to pull the charging cable from the bottom of my old iPod touch
tarafından
Yorum Ekle
13 Cevap
Filtre ölçütü:
Seçilen Çözüm
The older iPods required that they be disconnected from the USB port and plugged into an external power adapter i.e. wall charger. Once plugged into that it would perform the final step of the either restore or update. Just had to do the same last night with my old iPod. I've used either, a USB wall charger and an external firewire wall charger and it worked well with both. After this step the iPod was again recognized by iTunes. So I do not think that it is a cable or Firewire issue. The iPod 3rd generation is the one that truly needs firwire to be charged.
Bu yanıt yardımcı oldu mu?
Puan 5
2 Yorum:
I've just had this problem with a 4th Gen and plugging it in with a firewire adapter sorted it. Thanks for the tip.
tarafından
That is what I have been saying for months :-)
tarafından
Yorum Ekle
En Yararlı Yanıt
Hi there,
I had the same problem with my ipod classic 40 GB. The plug in wall charger icon come on and i left in plugged in wall socket for 2 days nothing happened.
Solution
Take a power bank fully charged. Take your ipod and plug in your USB cable in your power bank it will fix your ipod instantly. Cheers.
Hope this helps all you guys fix your ipods.
Puan 13
8 Yorum:
This worked for me! Thank you!
tarafından
was having a !&&* of a time with it, but thanks this answer solved the problem.
tarafından
i have struggled with that for a long time! thanks a lot for the help! I'm from Portugal and I thank God to see this solution!
tarafından
Thanks, worked for me
tarafından
Worked for me using an Old version of Itunes for the initial restore and then a fully charged external battery power supply - it helps to keep an old laptop with Windows XP as Windows 10 and the latest version of Itunes wouldn't work. Many thanks
tarafından
3 tane daha yorum göster
Yorum Ekle
Icon of Power adapter plugging into wall icon:
This icon appears on the screen during an update or restore that occurs when iPod is connected to the computer via a low or no-power connector. This can include some USB ports and 4-pin FireWire ports. When this appears, disconnect iPod from the computer and connect it to the power adapter. Then plug the power adapter into a power outlet. The update or restore will complete and iPod will restart to the main menu.
Puan 4
Yorum Ekle
Have you tried plugging it into the wall? If so, did you use a FireWire adapter? I believe the 4th generation sometimes required a FireWire charge to get it going after a period of unuse.
If you do not have a firewire charger, you could take it to the Apple store; the Genius bar still has a couple of FireWire chargers for just such emergencies.
Puan 1
2 Yorum:
Yes I have the same prob. It has to be a older apple usb or fire wire wall charger! a new type or aftermarkit wont work!!!
tarafından
I had the same issue what fixed mine was using a fairly new AC powerstrip that had USB ports for charging on it. I figured it would have more voltage than my phone charger and sure enough, it worked. You might try that too! It had me up and running within 20 seconds! Thanks for the advice!
tarafından
Yorum Ekle
I was able to fix this by using an iPad power adapter with the USB cable and not a standard USB Adapter - I think the higher power is required (if you remember, the original iPods came with the brick power adapter, not the mini plug ones)
Puan 1
2 Yorum:
Thanks, the iPad adapter worked!
tarafından
Yes, this actually worked for my iPod (the model U2 with storage 20GB)! At first, it didn’t respond, but here’s what I did: I fully charged my power bank, and then while the power bank itself was connected to charging, I plugged the 30-pin cable into the power bank — and boom, it started restoring the iPod properly. Seems like these older iPods really do need that stable, higher power input just like the old brick adapters. lol
tarafından
Yorum Ekle
Hi,
I had the same problem today. The iPod Mini 1st gen I ve just bought was stuck at the same step of the update. Even plugged in an 5 Volts USB wall charger, nothing happened...
The reason of this is that the old iPod wall charger delivered 12 Volts by Firewire and not 5 !
In fact, at this step of the update, my iPod wanted to receive 12 Volts and not 5. Without having such a power supply, I had to modify the original 30-pin dock to send 12 Volts in the right pins !
Now my iPod is fixed :) http://i58.tinypic.com/28srp07.jpg
(English is not my mother language so be kind :) )
Puan 1
2 Yorum:
see my comment. do not assume 12v is the key. i attempted this via variable power supply and it burned my board.
tarafından
Yes and I charged it with my car and it worked like a charm!
tarafından
Yorum Ekle
Hello,
if you are stuck after a restore and the ipod only shows "plugin wall" icon.
you need a standart USB wall charger but with a high Amperage (NOT VOLTAGE, voltage is 5v standard), probably 1A or even 2A . (original chargers had that high amp raatings too)
either USB or firewire cable would work. (most wall chargers are below 1amp)
ipod 4th gen 20gb
(upgraded to 1TB and Rockbox firmware)
Puan 1
1 Yorum:
Would you recommend trying to let it die fully and disconnect battery if you cannot get the charger needed ?
tarafından
Yorum Ekle
Well folks I might have the answer. I recently had the same problem - after an update the iPod actually got stuck. I tried everything finally I just let it completely die and voila. I plugged it again to the same wall charger and it worked. So maybe try that.
Puan 0
Yorum Ekle
Unhook the battery and wait a few minutes and then hook it back up. see the video link below on how to take it apart.
http://www.powerbookmedic.com/manual.php...
Puan 0
Yorum Ekle
all a load of rubbish, Apple are just a con, never using their crap products again, I have 2 iPod classics, both will not work
Puan 0
Yorum Ekle
I tried a couple different chargers including an iPhone charger, a generic USB charger and a battery pack with USB output and the only one that worked was the original iPod charger which puts out 5.2v instead of the usual 5v.
Puan 0
Yorum Ekle
20 GB Gen 3 iPod same issue, tried Samsung Fast Charger, Tab E Charger, Noco GB-40 Genius Jump Box. The only thing at my disposal that worked was a fairly new 120V Power Strip with a pair of USB Charging Ports labeled 2.1 Amp (Combined?), anyway the power-strip supplied enough Amperage to maintain the Voltage requirement of the iPod:)
Puan 0
Yorum Ekle
Wow, what a great tip to use the higher-powered (old-style brick) charger. I had just replaced the HDD in my old 4G iPod photo with a SDD but got stuck at the ‘plug into wall outlet’ icon. Thought she was a goner. Found a 10W brick from old iPhone/iPod and after a couple of cycles of apple icon and progress bar she was good to go. Tips like this are what the internet was made for. Thanks all.
Puan 0
Yorum Ekle
Yanıtını ekle
dnr sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 80
Her zaman: 42,270
