After changing the charging ic, a problem appeared with the touch?
Can you help guys?? My iPhone 15 Pro Mix was damaged and I changed the charging ic and the phone worked, but touching it works for two minutes and then stops.
Bu iyi bir soru mu?
Puan
0
I'm not clear on what it was you did; you've said you changed the charging IC and the charging cable. Did you actually do board level replacement of a BGA part, or did you just change out the lightning port assembly? Or are we just talking about replacing the USB-C charging cord? Which is it?
Jerry Wheeler tarafından
@dadibrokeit I changed the charging ic
خالد الصمدي tarafından
@khalid2021 Which version of the 15 pro Max is this? Is the US version? or the international version? (Does it have a SIM card slot?)
Alisha C tarafından
