Ana içeriğe geç
Random restart cpu 2 caller
Help! Iphone 11 restarts randomly
What is that?
Service center doesn’t know that problem
As a decision the suggested me just to change the battery, but that looks like the lottery
  "build" : "iPhone OS 16.0.2 (20A380)",
  "product" : "iPhone12,1",
  "socId" : "0x00008030",
  "kernel" : "Darwin Kernel Version 22.0.0: Tue Aug 16 20:50:57 PDT 2022; root:xnu-8792.2.11.0.1~1\/RELEASE_ARM64_T8030",
  "incident" : "4B22DF67-3C69-4679-9A80-DCD915AA072F",
  "crashReporterKey" : "0afec6380865981fc6cb2aa69465b558f3bfc015",
  "date" : "2023-11-25 12:20:45.55 +0300",
  "panicString" : "panic(cpu 2 caller 0xfffffff02646c38c): \"AppleSocHot: Hot Hot Hot (893D0DF0\/5575 89180EBC\/5893 09670D3C\/0 886D1268\/7362 81A332F9\/20389 88D71021\/6451, Ids 23\/7\/23\/16\/0\/4\/0\/0\/0, Perf 100\/100)\" @AppleSocHot.cpp:694\nDebugger message: panic\nMemory ID: 0x1\nOS release type: User\nOS version: 20A380\nKernel version: Darwin Kernel Version 22.0.0: Tue Aug 16 20:50:57 PDT 2022; root:xnu-8792.2.11.0.1~1\/RELEASE_ARM64_T8030\nFileset Kernelcache
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Your device is overheating to the point of a forced shutdown to prevent damage. ⚠️
" AppleSocHot: Hot Hot Hot " is the ios equivalent of tjmax on windows
Non repair Troubleshooting
Avoid using the device while charging.
Remove the case
Avoid games and apps that draw lots of computing power
Avoid having too many apps open at the same time.
Look into background battery usage to help identify which processes are using the most power. The power draw will be directly related to the heat produced.
Repair trouble shooting:
First, I'd back up, and factory reset the device in case some software misuses system resources
I'd look into the condition of the battery.
Check your liquid damage indicating paper stickers on the back of the screen in the sim tray and inside the device by the charging port and camera cluster.
Then, I'd check the logic board under a thermal camera to identify shorted or damaged components causing excess heat.
Adding thermal paste to the logic board is a viable option if you can't identify a clear cause for thermals to be high.
There are also active cooling accessories like the razer phone cooler you might see benefits from.
Hope this was helpful
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Peter sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 24
Her zaman: 518
