Ana içeriğe geç
The Xiaomi Redmi 9 is a low-budget smartphone by Xiaomi released June 2020. It has a 6.53" IPS LCD display, a 13 MP main camera, a rear-mounted fingerprint sensor, a 5020 mAh battery, and runs on a Mediatek Helio G80.
My phone is not turning on
this is only occur when my phone is already at 0% and it will shut down by itself, if i try to 'on' my phone, the redmi logo show up and then disappear. if i try to repeat and it will be the same. this is the same while charging. pls help ;-;
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
@johnrett this could be a battery issue as well as a charging board issue. For now, I would suggest that you start with the battery (do consider the charging board since you have the phone disassembled already) Also, check the ribbon cable from the charging board to the main board for any damage.
Since iFixit does not yet have specific guides for this, use the ones from here Those have been written in Spanish. Use a browser that will do the translating for you, if needed.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
John Rett sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 84
