Ana içeriğe geç
Ekim 2021'de piyasaya sürülen ve Apple tasarımı M1 Pro ve M1 Max çipleriyle (SoC) donatılmış 14 inç MacBook Pro için onarım rehberleri ve söküm bilgileri. Model A2442.
Ordering a replacement screen in Canada
I was curious about my ability to use the calibration tools when ordering a replacement display in an unsupported country?
I'm in Canada, and I have a US<>CAN shipping service I use frequently to order US items that don't directly ship to Canada. So getting the display should be no issue. But I wasn't sure if I would have problems using the tools to calibrate the display.
Has anyone in Canada used the tools? People mention running them through a VPN, but I just wanted to confirm if anyone's actually done that successfully.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Good question! I think you'll need to use a VPN which has a US IP address to make sure it goes as intended.
If you do try to get it to work with a Canadian IP and it works let us know! Otherwise its the VPN.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Just deciding whether it's worth the risk (as the screen is a really pricey part).
My only worry is that even with a VPN, i will still get shut down on account of the serial number being potentially visible to Apple as a Canadian device.
I'm just trying to read around a bit on what the worst case scenario is if the tool doesn't work. If it's only losing true tone than I'm mostly OK with that - but if there are issues with local dimming zones, then that will make the screen essentially useless to me.
tarafından
Yorum Ekle
Yanıtını ekle
George K sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 349
