Ana içeriğe geç
Dell Dimension 3000, 2004 yılından kalma orta seviye bir masaüstü bilgisayardır. 2 GB RAM ve tercih ettiğiniz bir Pentium 4, 4 HT veya Celeron işlemci seçeneğiyle piyasaya sürülmüştür.
PC started to smoke after CPU install
I had removed the CPU from my pc, it was working fine before I removed it. When I reinstalled it and booted it up, however, the pc power light and diagnostic lights all shut off, but the hard drive light and fans were still on, like if the pc was half off, and I couldn't shut it down through the power button. Since the cover was off, I managed to smell a little bit of smoke. I immediately unplugged the pc once I smelled the smoke. When I looked with a flashlight, there were no signs of damage or burning on the motherboard. I traced the smell, which didn't go away, and figured out it had came from the power supply. I couldn't see any burnt components, but the fan was really dusty, so that could be the issue. Please let me know if you had any suggestions.
Resim
Resim
Resim
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi, I read your story. If the power supply didn't burn out but it was very dusty then it could have just been a short, caused by the power supply, yes. Suggestion: Remove the power supply completely from its case and test with a multimeter and check if all outputs match the voltage specified by the manufacturer. 3.3v 12v 5v etc. as described on the box of your power supply.
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
I turned on the pc and it started working again, but thanks anyway! I’ll keep your post in mind :)
tarafından
[code]
Taking advantage of the fact that you have a photo of your processor without the cooler, clean it with paper and add new thermal paste and adjust the cooler.
[/code]
[code]
[/code]
tarafından
[code]
[/code]
[code]
[/code]
tarafından
Yorum Ekle
Yanıtını ekle
Dane Elliott-Dyson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 352
