Backlight stopped working, iBook G4
My friend's ibook G4 started having an intermittent backlight. It would only work at certain angles. Thought it was the cable (through the hinge) but have continuity. SO I saw the TH micro fuse answer, but that checks out OK also. So now I am thinking it is either: 1) inverter board or 2) display.
I was going to start with replacing the cable, but ordered a 184-000-1 but it is not the one for this display.Is 1" but connector is different at display end ;(
Because it was working at some display angles, I still suspect the cable or inverter.
Thanks,
Carl
Bu iyi bir soru mu?
