Why are all 3 usb ports dead
None of my usb ports work on my xbox series s. I've reset and everything
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi Steven!
So all of them are no longer working? Then it must be the USB controller on the motherboard which required to be replaced.
Bu yanıt yardımcı oldu mu?
Anyway to reset it to maybe get them back right??
Im afraid not… is everything up to date..?
@stevengeorge @dan0 looks like U407 got a "bit toasty". U407 is a TPS2001D USB power switch in a SOT23-5 package. It is available at mouser.com as well as digikey.com and many other places. Hope that is the one you both were referring too. Just in case, the capacitor just above it, is C1701 which is a 0.1µF 10% 25V capacitor in a 0201 package.
Hey @oldturkey03! Yes I agree. Looks like that one need to be replaced. Thanks for sharing the picture! I would start with those first.
I found an answer to this problem, you just need to do a jumper between pin 1 and 5!!!
Son 24 Saat: 7
Son 7 gün: 31
Son 30 gün: 151
Her zaman: 1,918
19 Yorum
Yes all three. If I out batteries in my controller and and plug it into the usb port it does like a buzz buzz vibration every like 30sec but it's constant if that makes sense. But it sucks bc I can't use external HD or anything.
Steven George tarafından
Hi Steven! I'm afraid that the USB IC need to be replaced on the motherboard to get your USB ports back to working.
koppie007 tarafından
Well that sucks. Just bought it from a pawn shop
Do you have any soldering skills? If not, you can bring it to a local repair shop and ask them to do the repair for you!
Ehhhhh not really I used an originak xbox one to practice and it didn't got too well but I have a whole series s taken apart bc the hdmi port and traces were messed up and then I got the one I use now.
14 tane daha yorum göster
