Ac is not cooling properly.Very minor cooling.Filters are also clean
Why is my voltas spilt ac not cooling properly? Checked the filters which is clean.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@juhipandey you did not tell us how the fan is running or even if it is turning on. If everything is as it should be, check the condenser coil. Make sure that it is clean and not full of debris. Clean it if needed. After that you will need to have to check the refrigerant and to make sure that is is fully charged. If you can tell us the exact model, we can hopefully find more information about the charge pressure and volume.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 174
Her zaman: 174
Yes it clean
oMaR HaRiDy tarafından
The model is fresh
The compressor doesn't start
@omarharidy Make and model for your AC? What have you checked? What does it do? Need more history.
oldturkey03 tarafından
