Why is my screen stuck on the red battery charge screen?
i took my iphone apart to make a repair to the plastic cover. i put everything back together and it was working just fine, but later the same day it died and sense then the only thing that comes up on the screen is the red battery charging sign when i plug it in.
Bu iyi bir soru mu?
16 Yorum
i have ordered a whole new back housing for the whole iphone. it only cost $50 with shipping and it is everything but the mother board and the screen, almost a whole new phone.
Drew tarafından
back housing is now installed... now my screen when plugged in goes off and on from the apple symbol
Drew tarafından
I found the solution! For reference I have an iPhone 5, and mine went into charging screen after I tried Upgrading into iOs 9.
If you've tried every single thing on the net hard reset, soft reset, cleaning charger port, etc. and still can't get it to get OFF the Charging Screen & You think you need a new battery, TRY this method first:
Let the iPhone completely die. Plug an original iPhone charger to USB cord & into your PC or Mac. While it's plugged in - Reboot the Laptop, this may take once or several trials before the iPhone finally turns on/or into the Apple Logo, eventually you will finally be able to sign onto iTunes, and restore, or restart your iPhone. Results : Go To www.everythingicafe.com search through the forums "iphone wont charge or turn on". I bought a Battery from here, thinking that was the issue, although my phone will need a new battery eventually ( due to dying quickly ) Nothing has worked for me, Until I tried those steps. Hope this helped.
emmawoodall85 tarafından
Thank you Emma. That worked for my iphone 3g too.
bojuto tarafından
Thank you Emma.....was without my phone all day! Tried everything I read on the net and was just about to go to the Verizon store and saw your comment above....it took me 3 reboots but it is working now!!! Thank you!!!!
Beth tarafından
11 tane daha yorum göster
