Ana içeriğe geç
PlayStation 3 (veya daha sık bilinen adıyla PS3), Sony Computer Entertainment tarafından üretilen üçüncü ev bilgisayar eğlence sistemidir ve PlayStation 2'nin akabinde devamı olarak üretilmiştir. 11 Kasım 2006'da piyasaya sürüldü.
No Power For Syscon Check
I recently picked up a PS3 Phat (CECHA01) with the YLOD. It has the COK-001 board. It had never been opened or serviced until now. I disassembled it and connected the UART to it to read the syscon errors. When I flip the switch on the power supply, I'm not getting any standby power (no red light on the control board). I confirmed the power supply is providing 5v to the board via the small 5 pin white cable. I also checked all the fuses (F6001, F6301, F6302, F6303, F6304) and they are good.
I currently only have the bare main board connected to the power supply via the white cable and the control board. Is anything else required to get the standby power on? All the syscon videos I've watched on YT are mixed. Some have it connected to just the white cable and other have it partially reassembled.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I found the issue. Connecting the DIAG wire to ground while in external mode on the UART will prevent access to standby power. Disconnecting the ground restored power and I was able to proceed.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
at1105 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 20
Her zaman: 380
