Ana içeriğe geç
50" Plasma TV by Sanyo released in 2007.
fuse by logic board keeps blowing
what component should i be looking for if the fuse by the logic board keeps blowing? is that board the power supply where the power chord enters the unit?
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
acloehlein, there are numerous things that could be causing that. Of course, first make sure that you have the right fuse. FT8ah250vp should be the one on the power board. If it continues to blow, you need to check the components on the logic board. Use a multimeter to check the Diode's, Caps and mosfets' on the board. Look for anything obvious, like charred components etc. Yes, that board is the powerboard and is available at places like this.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
acloehlein sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 1,505
