Ana içeriğe geç
Temmuz 2018'de piyasaya sürülen 15 inç MacBook Pro, model A1990, True Tone teknolojisine sahip 15,4 inç LED arkadan aydınlatmalı ekran, TouchID ve 6 Çekirdekli i9 işlemciye kadar seçenekler sunar.
Need help diagnosing display issues
My 2018 MacBook Pro display is shpwing flickering green and red lines, and occaionally blacks out or has a block pattern. I cannot locate any cracks in the screen, and the laptop has not been dropped since I have owned it. Graphics display perfectly when using Airplay to cast to my TV. Does this seem to indicate a display cable issue, or should I be looking at replacing the screen? Thanks in advance for the help.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
This is most likely due to a failing display flex cable, which unfortunately is integrated into the display assembly. This is a common design problem with these models (2016-2018ish Pros). Unfortunately you'll need to replace the display assembly to repair the device. Sorry!
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
That’s what I thought originally, I just needed some confirmation before I under the process. I already bought a replacement display as simply, I just had not installed it. If there was any other options, I wanted to explore that first. Thanks a bunch!
tarafından Paylaş
Yorum Ekle
Resim
Saludos que me recomienda MacBook Pro 2018 15 pulgadas modelo a1990
Puan 0
Yorum Ekle
Yanıtını ekle
Tanya Robinson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 25
Her zaman: 307
