Ana içeriğe geç
Miyoo Mini, Miyoo tarafından 2 Aralık 2021 tarihinde piyasaya sürülen bir açık kaynaklı el konsoludur. Miyoo Mini son derece küçüktür; cebinize istediğiniz zaman koyabilir veya cebinizden çıkarabilirsiniz. Temel fiyatı 269,00 RMB'dir.
Why is my screen black
i believe i miss up my miyoo mini it was in miyoo ui and i put a onoin os sd card with an update it install but the screen turn black it turns on i can here sounds still just i can see anything I tried putting the old sd car with ui in it nothing i turned it off and turn it off and on still nothing I know it is dumb but i didnt know this would happen. you think it is fix able
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi!
This is most likely an software issue.. So if I'm correct, it failed after you've tried to install a firmware update for this device?
If this is the case, the best thing to do is to contact Miyoo. You could replace the motherboard to fix it, but this will be expensive.
Hopefully Miyoo do have something to re-flash the device so that it can be used again instead of replacing the motherboard....
If you are wondering regarding the motherboard replacement, here is a video: https://www.youtube.com/watch?v=6R2h4kfW...
Please let us know how it goes!
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
This is for the miyoo mini plushic i have the regular small one wh is the miyoo mini not the plus but thank you for your help
tarafından
Hi! My pleasure! Is this the video for your model? https://www.youtube.com/watch?v=97kOOxP3...
Have a nice day!
tarafından
Yorum Ekle
Yanıtını ekle
Flux sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 47
Her zaman: 1,128
