Ana içeriğe geç
{A1989 / EMC3214}—Released in July 2018, the 13" MacBook Pro features quad-core i5 and i7 processors and Intel Iris Plus integrated graphics.
Why is my screen neon and flickering
My MacBook screen now has neon/inverted colors all over and there’s a slight flickering or shakiness of the screen. But when I put my screen down close to the keyboard then the screen goes back to normal but when I lift it back up halfway and eventually all the way, the screen goes back to flickering neon. How do I fix this?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Not good!😫
The display ribbon cables have become damaged, this will require a new display as the ribbon cables can’t be replaced. You might find someone really skilled in micro soldering who could patch the cable.
But I’ll worn you this patch won’t last as you flex the lid and the cause of the damage could be a hard plastic shell or even a paper clip sitting near the hinge area which damages the glass chin plate.
This plate covers the cables to the LCD panel a glass shard often cuts the cable. If you live with a lot of grit in the air or get sand into the hinge area both can wear the cables as well.
Here’s the guide with the needed part listed MacBook Pro 13" Touch Bar 2018 Screen Replacement
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Carlie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 9
Her zaman: 143
