Ana içeriğe geç
Mac Pro olarak bilinen masaüstü Mac serisinin 2013 yenilemesi.
Is it time to upgrade?
Hi I have a 2013 mac pro 3.5GHZ 6 core SN 5KW4OBKF694 what is recommended to change? CPU. processor... or should I break the bank and get another machine?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
This question was migrated from https://meta.ifixit.com/Answers.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
What are you primarily using the machine for? If you're using it for work like photography and video work such as Affinity Photo/designer/publisher or Adobe CC, those are long in the tooth, to the point they're beginning to show their age. You may consider an upgrade, but a better SSD (Apple OEM or a compatible SSD that doesn't need to be adapted) like this may help you get a bit more life out of it, but it may not be much.
If you use it for less intensive work, slap an SSD in it, and you'll easily get a few more years out of it. There is no need to upgrade unless you want a machine that isn't a pig in terms of power consumption, given that the Xeon processors were always known for being heavy on power consumption—sometimes as much as a laser printer in a dual Xeon setup with a professional grade GPU like a Radeon Pro/FirePro or Quadro!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
I have a 2013 Trash Can and it’s still holding up! Sure the system is limited with a peg leg GPU as the dual GPU setup never caught on. Even still the one GPU wasn’t bad!
Your work flow and needs is how I look at this. Having the fastest car won’t help you in stop and go traffics, and in the same light the time of processing you are doing on your system is how you need to look at and if it’s time to upgrade.
Puan 0
1 Yorum:
Like for example how I came from a 2015 Intel R9 Retina to a M1 Pro 16". I went for it because I noticed programs like Affinity Photo and Designer 2 were being more optimized for AS and less for Intel, so as time went on (as well as the age of Haswell catching up), the programs I run were bogging down the machine 9 years later.
tarafından
Yorum Ekle
Yanıtını ekle
casey sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 298
