Ana içeriğe geç
22 Eylül 2017'de satışa sunuldu. Model A1863, A1905 olarak tanımlanıyor. GSM ya da CDMA olarak 64 ya da 256 GB kapasitelerinde, Altın, Gümüş, ve Uzay Grisi renklerinde satılır.
iPhone 8 boot looping while charging, otherwise shutdowning
Hello!
What's happening:
  • while charging, the phone boot loops and sometimes boots to iOS until it restarts again after ~3 seconds (during this time I can also see that my battery is reported to have 100% charge)
  • while not charging it "likes" to say shutdown, when trying to boot it up (or force restarting) it just shows the Apple logo and shutdowns again
What have I tired:
  • changing the power adapter and cable
  • checking and cleaning the charging port
  • tried wireless charging
  • restoring the phone
I am not sure if it's because of a faulty battery and would like to know any other possible solutions (or even problems) before changing it.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
This definitely sounds like a battery would be a good start, but we can check for a few clues before actually repairing if the phone will stay up for long enough to do so.
If the phone will actually boot (I couldn't tell from your description if it ever booted properly and stayed up) I would check two things: your battery health, and if there are any panic logs present. Battery health can be found in the battery section of settings. And kernel panic logs can be found in the analytics settings. You can use the iPhone Kernel Panics page to locate them and there is some info in interpreting them on the page as well, but if it comes to that, it might be better to post them here so we can have a look.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Yes the phone does boot, but it just boots to the lock screen and then shutdowns so I wouldn't have been able to check anything. However I think found a way so it wont shutoff while charging (it has to be plugged in to the wall while being actually fully charged, I guess it doesn't drain the battery anymore and just straight takes the charge from the outlet).
Those side notes beside, the battery health is reported as "service" while having 76% maximum capacity. Also there aren't any kernel panic logs
tarafından
@vbxltkrqvu If the battery is reporting "Service" and it behaves better when plugged into wall power, that seems like a battery issue to me. You mentioned you already reset the phone?
If it's still happening then it definitely points to a hardware issue and if no kernel panics, sounds like the power is just getting pulled. Or at least not making panics when it crashes.
New battery sounds like it's in order.
tarafından
Yorum Ekle
Yanıtını ekle
vbxltkrqvu sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 88
