Ana içeriğe geç
Kasım 2017'de piyasaya sürülen Oppo F5, 16:9 yerine 18:9 ekran kullanan ilk akıllı telefondur. 6,0 inçlik bir ekrana sahip olmasına rağmen, F5'in genişliği 16:9 oranına sahip 5,5 inçlik ekranlarla benzerdir. Model numaraları CPH1723 ve CPH1727.
How to fix the booting loop?
i just reset my phone and then the screen is not changing anymore i try to use the recovery mode but it didnt work
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
@oldturkey03 the robot got my one of the comment and I am running low now. Please have look at it. Take it back, read it (as it is for you only) and then I will delete it
tarafından Paylaş
Yorum Ekle
2 Cevap
Filtre ölçütü:
Hey hi zyro, the only thing I can suggest you at this point is a hard reset.
To do a hard reset, following the given steps:
1) Shutdown your phone
2) Put it in recovery mode (I assume you know it because you saved you tried putting it in recovery mode)
3) Wipe data or just do a factory reset
4) Reboot the system
If Hard reset also does not work then it might be just software update, also try charging the battery for a while (irrespective of it showing a sign of charging or no, just put in the cable, turn on the charger and take it back off after 20mins)before attempting a hard reset.
Thank you for reading and have a gorgeous day =)
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Well I will suggest you to checkout the following video:
https://www.youtube.com/watch?v=tHWQbbmi...
Puan 0
Yorum Ekle
Yanıtını ekle
zyro sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 30
Her zaman: 944
