Ana içeriğe geç
Restarting every 3 minutes PRS0
My iphone 11 is restarting every 3 min. Im not fluent in english, sorry.
I had put it on assistance to fix the power button, he came fine. 2 months post i accidentally dropped him in a pool and he instantly turned off. Another guy tried to replace the battery and flex cable but didnt worked.
Heres the panic full
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
This is an extremely common problem, especially on iPhone 11. The PRS0 sensor refers to the pressure sensor" which is on the charge port flex cable. So that's where I would start. It's especially common with liquid damage since it's on the bottom edge of the phone by the microphone grille, where water could get in.
Getting a high quality replacement cable is a must with these. Lower quality cables are likely to have the same issue.
I am going to assume that the flex cable that was replaced already was the power button cable since you mentioned the power button wasn't working? (Just making sure I mention things that haven't been tried already). But correct me if I'm wrong.
Replace a lightning connector assembly compatible with the iPhone 11. Includes the flex cable, logic board connector, lightning connector socket, and one microphone. Part #821-02037. Görseli
Ürün
iPhone 11 Lightning Connector Assembly
$24.99
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Hi where you able to fix it? I have the same problem
tarafından
Yorum Ekle
Yanıtını ekle
conta vava sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 97
Son 30 gün: 316
Her zaman: 1,553
