Ana içeriğe geç
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2376 Soru Tümünü görüntüle
iPhone 4 Won't Turn On After Attempted Restore
For the past year, my iPhone 4 locks up every now and then (it does not let me slide to unlock) but it always began to work again after 4 or 5 force restarts. A couple days ago, this happened, but it did not work after many force restarts. I restored it to factory settings, and I got to the part where it says to let your phone restart, but after it did, the iPhone turned off and now it will not turn back on. iTunes cannot see it and I have tried charging it and it does not work. It had iOS 5.1.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
By the way, the phone hasn't been damaged or dropped in water or anything like that.
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
What happens when plugged into mains power? Your Battery main have just DIED or at best gone fully flat. Which can only be recovered by the mains power. Do you get a flashing red Battery symbol with a lightning bolt? Leave for 1 to 2 minutes to see if it gaining a charge and pull the plug. If it shuts straight off then time for a new Battery.
You can purchase from here.
iPhone 4 Replacement Battery - Does not require soldering
I hope that gives you some direction.
iPhone 4 Battery Görseli
Ürün
iPhone 4 Battery
$11.99
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Yep that was it. Thanks, but now it is at the iPhone startup screen for setting up a new device, and it still freezes when I slide the slider.
tarafından
Yorum Ekle
I'm having the exact problem. Did you manage to find a solution?
Puan 0
Yorum Ekle
im having the exact same problem . ive tried holding down the home and power buttons but it doesnt work
Puan 0
Yorum Ekle
i tried reseting my jailbroken 4s. and now its not turning on.... help.<>,.,.,<>
Puan 0
Yorum Ekle
hold power and home button while itunes it open and iphone is lugged into pc, it should work
Puan 0
Yorum Ekle
Yanıtını ekle
Garrett Fletcher sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 11,495
