Ana içeriğe geç
Can the Micro-Usb port be replaced?
I damaged the port by forcing a mini-usb cable into it. Can it be easily replaced?
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Alfonso Navarro, this depends on your skill level. Check the teardown on here. you can see that the USB port is actually pretty easy to locate on the logic board, but it is solder onto it. So two obstacles, first you will have to find a replacement, second you will have to de-solder the old one and re-solder the new one. Not an impossible repair, but it does require patience and some practice. You could try mouser.com or digikey.com for a replacement part. Check here for moreinfo about the micro USB. Hope this helps, good luck
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Alfonso Navarro sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,005
