Ana içeriğe geç
The Hakko FX-888D is a digital soldering station manufactured by Hakko.
It is not heating
Non heating problem
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hello,
I had this problem one time. In my case it turned out to be the ceramic heating element. Hakko should be able to either repair it or send you a replacement part. If it is new, contact them and ask what your options are. If it's been in use for a while, you could check the ceramic by unscrewing the retaining nut that holds the hot end and carefully slide off the steel sleeve and inspect the ceramic. The ceramic is very fragile, so be very careful just in case it's not broken and the problem is a different component.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Riddhyansh ojha sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 13
Her zaman: 90
