Ana içeriğe geç
Mi 9, Xiaomi tarafından Şubat 2019'da piyasaya sürülen orta sınıf bir akıllı telefondur. 6.39" süper AMOLED ekrana, 48 MP ana kamera ile birlikte ultra geniş açı 16 MP lense ve 12 MP telefoto lense sahiptir. Ayrıca cihazda, ekran altı parmak izi okuyucu ve hızlı kablosuz şarj özelliğine sahip 3300 mAh pil yer alıyor.
Handphone saya tiba-tiba mati.. My cell phone suddenly died..
Handphone saya tiba-tiba mati..Lama sikit baru dia on..now tak boleh on.. Kenapa ya?
Translation Malay - English
My mobile phone suddenly turned off.. It's been a while since it turned on.. now it can't turn on.. Why?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
@sitimaztur60213 this sounds like a depleted battery. For now, I would suggest that you replace the battery. Also, check the charge connector and your charger to make sure those are in good working condition. Check the charging port and clean it of any debris etc, use a few puffs of air to clean it out. Make sure there is no corrosion, debris etc. that prevents it from working..
The only other thing I would consider is to replace the sub_board (charging board) as well as checking the flex cable that connects the sub_board to the main board. Since iFixit does not yet have a specific guide for this, use this one for the battery and this one for the sub_board. Both of these guides are written in Spanish. Use a browser that will do the translation for you.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@sitimaztur60213 ini bunyi seperti bateri yang habis. Buat masa ini, saya cadangkan anda menukar bateri. Juga, periksa penyambung pengecas dan pengecas anda untuk memastikan ia berada dalam keadaan baik. Periksa port pengecasan dan bersihkannya daripada sebarang serpihan dll, gunakan beberapa hembusan udara untuk membersihkannya. Pastikan tiada kakisan, serpihan dll yang menghalangnya daripada berfungsi..
Satu-satunya perkara lain yang saya akan pertimbangkan ialah menggantikan sub_board (papan pengecasan) serta memeriksa kabel flex yang menghubungkan sub_board ke papan utama. Memandangkan iFixit belum mempunyai panduan khusus untuk ini, gunakan yang ini untuk bateri dan yang ini untuk sub_board . Kedua-dua panduan ini ditulis dalam bahasa Sepanyol. Gunakan penyemak imbas yang akan melakukan terjemahan untuk anda.
Semasa anda menggunakan telefon anda, ambil banyak gambar. Sebaik sahaja anda selesai dengannya, ambil gambar tersebut dan buat panduan untuk iFixit. Itu akan membantu orang seterusnya yang mempunyai peranti dengan isu yang sama seperti anda. Mudah dan menyeronokkan untuk mencipta panduan ini. https://ifixit.com/Guide/new Komuniti iFixit akan menghargai perkara ini.
Pembaikan adalah Perang terhadap Entropi!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Siti Maztura Binti Mazlan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 46
