The front of the power adapter cable is broken, it does not work
The front of the power adapter cable is broken, it does not work, My laptop is out of battery so I can't turn it on, help me
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@furkanergun either you replace the complete power adapter or you can simply replace the front barrel adapter. You’ll need a 4mm (outside diameter)x1.3mm(inside hole diameter) and solder it to where the old one was. Cut that off, use a multimeter to determine polarity and solder the negative to the outside contact and negative to the hole connector. Not terribly complicated but do let us know if you have trouble with that.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 13
