Ana içeriğe geç
Bu Power Mac G4, Mirrored Drive Doors (Yansıtmalı Sürücü Kapakları) modeline sahiptir.
FireWire Target Disk Mode Not Working?
Hello, recently, i bought a firewire 400 cable to connect my iBook G3 to my PowerMac G4 MDD, to transfer files too large to for my flash drive. The cable finally arrived today, and I set the iBook to restart into target disk mode in system preferences, and connected the cable to both computers, it rebooted, and showed a yellow firewire logo, on a blue screen. However, My Powermac G4 never found the iBook, I tried connecting the cable to both of the firewire ports on the Logic board, and the other two on my expansion card, but nothing, it couldn't find the iBook, not even in disk utility. I also tried putting the PowerMac into Target disk mode, and the iBook couldn't reconize it. I'm not too farmilier as to how to use target disk mode, but it seems i did everything right. I also tried removing the expansion card in the PMG4, but still nothing, I don't have any other devices to test the cable. I also have a couple other cards in the powermac (SCSI, Sound) should I remove those as well? Did I forget anything to get this too work?
Bu iyi bir soru mu?
Puan 2
1 Yorum
What Mac OS are you using on the computer you are trying to use as target?
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Try starting the PowerBook up holding the "T" key instead of using system preferences. Boot the PowerBook first then the MDD.
Bu yanıt yardımcı oldu mu?
Puan 4
7 Yorum:
I tried that, but it still does this.
tarafından Paylaş
The cable has to be suspect. What you did should work.
tarafından Paylaş
Ok, thanks. i might test it with a meter to see if it is messed up.
tarafından Paylaş
Remember the machine that is trying to be used in target mode must be Mac OS X
tarafından Paylaş
The cable was bad, I just decided to pay an arm and a leg at Best Buy, and get a new one and now it works.
tarafından Paylaş
2 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Chris Green sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 23
Her zaman: 6,401
