Where is the thermostat sensor on Chevy Colorado 2017
Where is the thermostat sensor located on a 2017 Chevy Colorado
Bu iyi bir soru mu?
Bu iyi bir soru mu?
In the 2017 Chevy Colorado, the thermostat sensor is located near the thermostat housing, which is typically on the engine block or cylinder head, connected to the upper radiator hose.
Bu yanıt yardımcı oldu mu?
There is no such thing, thermostate is a passive actuator which only works when coolant temperature change, opens when coolant temp goes up and closes when it drops.
It does not need and electric power supply and will not provide any signal to computer, it just works passively.
I assume you mean coolant temp sensor? Or just trying to find thermostate itself?
Indeed you are correct as to I meant the coolant temperature sensor, Please and Thank you.
Son 24 Saat: 0
Son 7 gün: 17
Son 30 gün: 18
Her zaman: 18
