green vertical lines bottom half of screen
i`ve tried everthing even resetting but still there any help would be great
Bu iyi bir soru mu?
Bu iyi bir soru mu?
In my phone fixing experience, if the display isn’t physically damaged from impact pressure or heat; it’s always the ribbon cable, you tried reseating it already so can you get your hands on another ribbon? If so and you have the same exact pattern of green lines then maybe the connector is the issue, probably a cold/cracked solder joint if the connector were bad
Ribbon cables can also be a pain to seat correctly, no harm in giving it a couple more shots
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 6
Son 7 gün: 7
Son 30 gün: 7
Her zaman: 7
