Ana içeriğe geç
Jura'nın küçük makineleri. Farklı modelleri bulunsa da onarımları neredeyse aynıdır.
Machine keeps saying press rinse
Machine says press rinse repeatedly
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
When you rinse, does water come out? So my first idea is the flowmeter. Is it perhaps clogged and therefore not reporting any water flow to the electronics? Open the machine. Step 12, first picture shows the flowmeter, the small white round box next to the brewing unit. Open it and clean it, as described e.g.here.
Jura ENA micro 9 Görseli
Kılavuz
Jura ENA micro 9 açma
Zorluk:
Orta
Jura Impressa S85 Flowmetre Görseli
Kılavuz
Jura Impressa S modelleri flowmetre değişimi/revizyonu
Zorluk:
Orta
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
This totally saved my Jura from sending it in for repairs thank you so much although what happened was I did everything,cleaned it put it back together and it still kept saying rinse. I reversed the tubes because I wasn’t sure if I put them incorrect and tried it a few more times it kept saying the same thing so I figured I was going to send it in but then I reverse them back again to the proper way and now it works like a charm. Maybe it just needed to unclog something and the reversing of the tubes did that. in any event thank you very much.
tarafından
@kimwoodbridge So the flowmeter - as often - was the culprit. The channel where the water flows in is very narrow, for sure it was clogged. Congratulation to your repair!
tarafından
Yorum Ekle
Yanıtını ekle
John sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 23
Son 30 gün: 81
Her zaman: 1,159
